Latest stable-daily installs SRPM macros and other rpm tools
I just wanted to ask if it was intentional to install (Added) a bunch of SRPM macros and other rpm dev tools that I received today, as part of the current stable-daily update?
I don’t see such a change in the github commit history, do they come as new dependencies to an existing package?
Please see below:
Pulling manifest: ostree-image-signed:docker://ghcr.io/ublue-os/aurora-dx:stable-daily
Importing: ostree-image-signed:docker://ghcr.io/ublue-os/aurora-dx:stable-daily (digest: sha256:300cc848dc705031424c8403f35994b7fa78bebcb8400e41935cb1339e170971)
ostree chunk layers already present: 69
ostree chunk layers needed: 3 (317.8 MB)
[0/3] Fetching ostree chunk fb6c76b67d89cdf70c6 (115.7 MB)... done
[1/3] Fetching ostree chunk 2efdad02c786c538d50 (189.8 MB)... done
[2/3] Fetching ostree chunk 6ac08403d0dff67d10e (12.3 MB)... done
Staging deployment... done
Freed: 273.2 MB (pkgcache branches: 0)
Upgraded:
  clevis 21-7.fc41 -> 21-8.fc41
  clevis-luks 21-7.fc41 -> 21-8.fc41
  code 1.96.2-1734607808.el8 -> 1.96.3-1736454428.el8
  containerd.io 1.7.24-3.1.fc41 -> 1.7.25-3.1.fc41
  docker-ce 3:27.4.1-1.fc41 -> 3:27.5.0-1.fc41
  docker-ce-cli 1:27.4.1-1.fc41 -> 1:27.5.0-1.fc41
  docker-ce-rootless-extras 27.4.1-1.fc41 -> 27.5.0-1.fc41
  docker-compose-plugin 2.32.1-1.fc41 -> 2.32.3-1.fc41
  fastfetch 2.33.0-1.fc41 -> 2.34.1-1.fc41
  gum 0.14.5-1 -> 0.15.0-1
  kcli 99.0.0.git.202501131118.e506c0b-0.fc41 -> 99.0.0.git.202501131614.0e60f41-0.fc41
  rclone 1.67.0-2.fc41 -> 1.68.2-1.fc41
Downgraded:
  kernel 6.11.11-300.fc41 -> 6.11.8-300.fc41
  kernel-core 6.11.11-300.fc41 -> 6.11.8-300.fc41
  kernel-devel 6.11.11-300.fc41 -> 6.11.8-300.fc41
  kernel-devel-matched 6.11.11-300.fc41 -> 6.11.8-300.fc41
  kernel-modules 6.11.11-300.fc41 -> 6.11.8-300.fc41
  kernel-modules-core 6.11.11-300.fc41 -> 6.11.8-300.fc41
  kernel-modules-extra 6.11.11-300.fc41 -> 6.11.8-300.fc41
  kmod-xone 0.0.git.251.c7fb361c-1.fc41 -> 0.0.git.218.d8c42b2e-1.fc41
Added:
  add-determinism-0.3.6-3.fc41.x86_64
  akmod-xone-0.0.git.251.c7fb361c-1.fc41.x86_64
  akmods-0.6.0-8.fc41.noarch
  annobin-docs-12.69-1.fc41.noarch
  annobin-plugin-gcc-12.69-1.fc41.x86_64
  ansible-srpm-macros-1-16.fc41.noarch
  build-reproducibility-srpm-macros-0.3.6-3.fc41.noarch
  efi-srpm-macros-5-13.fc41.noarch
  fakeroot-1.36.2-1.fc41.x86_64
  fakeroot-libs-1.36.2-1.fc41.x86_64
  fonts-srpm-macros-1:2.0.5-17.fc41.noarch
  forge-srpm-macros-0.4.0-1.fc41.noarch
  fpc-srpm-macros-1.3-13.fc41.noarch
  gcc-plugin-annobin-14.2.1-3.fc41.x86_64
  ghc-srpm-macros-1.9.1-2.fc41.noarch
  gnat-srpm-macros-6-6.fc41.noarch
  go-srpm-macros-3.6.0-5.fc41.noarch
  grubby-8.40-78.fc41.x86_64
  kernel-srpm-macros-1.0-24.fc41.noarch
  kmodtool-1.1-11.fc41.noarch
  libgit2-1.8.4-1.fc41.x86_64
  llhttp-9.2.1-2.fc41.x86_64
  lua-srpm-macros-1-14.fc41.noarch
  ocaml-srpm-macros-10-3.fc41.noarch
  openblas-srpm-macros-2-18.fc41.noarch
  package-notes-srpm-macros-0.5-12.fc41.noarch
  perl-srpm-macros-1-56.fc41.noarch
  pyproject-srpm-macros-1.16.4-1.fc41.noarch
  python-srpm-macros-3.13-3.fc41.noarch
  python3-babel-2.16.0-1.fc41.noarch
  python3-click-plugins-1.1.1-22.fc41.noarch
  python3-progressbar2-3.53.2-13.fc41.noarch
  python3-pygit2-1.16.0-2.fc41.x86_64
  python3-rpmautospec-0.7.3-1.fc41.noarch
  python3-rpmautospec-core-0.1.5-2.fc41.noarch
  python3-utils-3.7.0-6.fc41.noarch
  qt5-srpm-macros-5.15.15-1.fc41.noarch
  qt6-srpm-macros-6.8.1-4.fc41.noarch
  redhat-rpm-config-293-1.fc41.noarch
  rpm-build-4.20.0-1.fc41.x86_64
  rpmdevtools-9.6-8.fc41.noarch
  rust-srpm-macros-26.3-3.fc41.noarch
  systemd-rpm-macros-256.11-1.fc41.noarch
  zig-srpm-macros-1-3.fc41.noarch
Run "systemctl reboot" to start a reboot
These appear to be pulled in when we pinned a kernel, the team is investigating, thanks!
Is this maybe related to the openrazer stuff, as per this comment.
For some reason this seems to only affect the stable/stable-daily streams. For example -latest stream on both Aurora or Bluefin don’t seem to have those packages.
Hi @inffy, is this still under investigation? I still have these packages in today’s build too.
These are dependencies of akmods that are being pulled in due to kernel pinning. This is our best guess (from the discussion on Discord):
But yes it’s something with akmods where it thinks it needs to be installed for the RPM to install from akmods
I don’t think these packages are harmful to be present on the system and they should go away when the kernel is unpinned.
