Kinoite (Main) - No rpm-ostree in Discover
I tried to add rpm-ostree update funktion in discover by installing “plasma-discover-rpm-ostree” as overlay package (rpm-ostree install …) in kinoite-main:latest image.
But it alsways tells me:
Inactive requests:
plasma-discover-rpm-ostree (already provided by plasma-discover-rpm-ostree-6.1.4-1.fc40.x86_64)
How can i solve this problem? Or can you add this package to the system image in the future?
Why would this be added? Tou should avoid layering things as much as possible
Because i want use Discover to update the system like in normal Fedora Kinoite where this package exists in die OCI image.
Well rhe main images are not meant to be used, as they are just bases for bluefin/aurora.
Just seeing at as useless vloat on a -main image.
You can of course build your own and add that package
