KDE setting reset
Is it expected for KDE setting to get reset update base image update?
I setup up my max charge level in advanced power setting to 60%, and after some time I discovered it’s set back to 100%.
I’m assuming it’s due to update, but I cannot be sure, because I didn’t notice it immediately. Is this expected?
Same issue here. In Power Management => advanced power settings when I decrease the max charge, it will reset back to 100% on reboot.
I have seen on other posts regarding other bazzite features that this has been intended, and suggestions were made to alter the config file directly at the command line. Have been trying to find this line of code but can’t find the right config file/lone. Would anyone be able to help here?
Thanks
In case anyone finds this later, the file is located in etc/default/batterylimit, but unless your on the steam deck it doesn’t seem to alter the charge limit. After a bunch of tinkering, I was able to set this through HHD, but I had to uninstall simpledeckyTDP to get it to work in HHD
