Insufficient space left in bootfs
I’m on stable-daily, and I was not able to apply yesterday’s update this morning, because the bootfs seems full. All updates were working in the previous months. I assume it is somehow related to this change: chore(ci): support combined akmods-kernel-cache in build by bsherman · Pull Request #182 · ublue-os/aurora · GitHub
Note: I did not change the recommended partition layout when installing Aurora from scratch a few months ago. (But I selected manual partitioning, then clicked to create the default recommended layout, and just accepted that - after renaming the btrfs volume.)
Should I somehow have a larger /boot? Or shouldn’t it have filled up?
Note2: Did not yet have time to retry it or try it with another image.
State: idle
Warning: failed to finalize previous deployment
         error: Installing kernel: regfile copy: No space left on device
         check `journalctl -b -1 -u ostree-finalize-staged.service`
Deployments:
● ostree-image-signed:docker://ghcr.io/ublue-os/aurora-dx:stable-daily
                   Digest: sha256:781d39a91bea15441f4ce7bd85359d65bd458316e03f951fad3d567631feb966
                  Version: 41.20250205.8 (2025-02-05T18:16:11Z)
                   Digest: sha256:ae714eb63ce850983151c89ab77ca243bd07fd7de41467c51a2a56fdfa251734
                  Version: 41.20250205.3 (2025-02-05T07:18:46Z)
                   Pinned: yes
                   Digest: sha256:d135686f77be55dfe6fad6dd277d4e32e53ca749fe144bc11efebd0bed0cb90c
                  Version: 41.20250113.6 (2025-01-13T07:23:23Z)
                   Pinned: yes
                   Digest: sha256:c31b9ddf427fdb7f14561e1d66e409749e4f29e40dd9712a53ee524bdd8e5db7
                  Version: 41.20250105.1 (2025-01-05T19:24:15Z)
          LayeredPackages: brave-browser
                   Pinned: yes
                   Digest: sha256:919dc0378dbc59ade5f1a9e9af5889ce81c8ace0193429293686db97408fc709
                  Version: 41.20250109 (2025-01-09T06:07:09Z)
                   Pinned: yes
                   Digest: sha256:66e734492af55b17deb6172d7de8e63543f812ab0baa766ed3d70fa9c86a4380
                  Version: 41.20241220 (2024-12-20T06:10:08Z)
                   Pinned: yes
❯ journalctl -b -1 -u ostree-finalize-staged.service
Feb 06 08:46:36 hostname systemd[1]: Finished ostree-finalize-staged.service - OSTree Finalize Staged Deployment.
Feb 06 08:50:06 hostname systemd[1]: Stopping ostree-finalize-staged.service - OSTree Finalize Staged Deployment...
Feb 06 08:50:07 hostname ostree[9004]: Finalizing staged deployment
Feb 06 08:50:08 hostname ostree[9004]: Copying /etc changes: 30 modified, 6 removed, 150 added
Feb 06 08:50:08 hostname ostree[9004]: Refreshing SELinux policy
Feb 06 08:50:11 hostname ostree[9004]: Refreshed SELinux policy in 2664 ms
Feb 06 08:50:11 hostname ostree[9004]: Finalized deployment
Feb 06 08:50:11 hostname ostree[9004]: bootfs requires additional space: 167.8 MB
Feb 06 08:50:11 hostname ostree[9004]: Size to prune from bootfs: 0 bytes
Feb 06 08:50:11 hostname ostree[9004]: Disabling auto-prune optimization; insufficient space left in bootfs
Feb 06 08:50:12 hostname ostree[9004]: error: Installing kernel: regfile copy: No space left on device
Feb 06 08:50:12 hostname systemd[1]: ostree-finalize-staged.service: Control process exited, code=exited, status=1/FAILURE
Feb 06 08:50:12 hostname systemd[1]: ostree-finalize-staged.service: Failed with result 'exit-code'.
Feb 06 08:50:12 hostname systemd[1]: Stopped ostree-finalize-staged.service - OSTree Finalize Staged Deployment.
Feb 06 08:50:12 hostname systemd[1]: ostree-finalize-staged.service: Consumed 3.982s CPU time, 112.8M memory peak.
❯ df
Filesystem     1K-blocks     Used Available Use% Mounted on
/dev/dm-0      248378368 71151384 173891192  30% /sysroot
devtmpfs            4096        0      4096   0% /dev
tmpfs            3999320       84   3999236   1% /dev/shm
efivarfs             100       67        29  71% /sys/firmware/efi/efivars
tmpfs            1599732     2248   1597484   1% /run
tmpfs               1024        0      1024   0% /run/credentials/systemd-cryptsetup@luks\xyz\xyz\xyz\xyz\xyz.service
tmpfs               1024        0      1024   0% /run/credentials/systemd-journald.service
tmpfs               1024        0      1024   0% /run/credentials/systemd-udev-load-credentials.service
tmpfs               1024        0      1024   0% /run/credentials/systemd-network-generator.service
tmpfs               1024        0      1024   0% /run/credentials/systemd-tmpfiles-setup-dev-early.service
tmpfs               1024        0      1024   0% /run/credentials/systemd-sysctl.service
tmpfs               1024        0      1024   0% /run/credentials/systemd-tmpfiles-setup-dev.service
/dev/dm-0      248378368 71151384 173891192  30% /var
/dev/dm-0      248378368 71151384 173891192  30% /var/home
overlay        248378368 71151384 173891192  30% /usr/share/sddm/themes
tmpfs            3999324        4   3999320   1% /tmp
/dev/sda2         996780   976516         0 100% /boot
/dev/sda1         613160    12856    600304   3% /boot/efi
tmpfs               1024        0      1024   0% /run/credentials/systemd-vconsole-setup.service
tmpfs               1024        0      1024   0% /run/credentials/systemd-tmpfiles-setup.service
tmpfs               1024        0      1024   0% /run/credentials/systemd-resolved.service
tmpfs             799864   104376    695488  14% /run/user/1000
Do you have any suggestions how I could fix this most easily?
Thanks!
You have pinned too many images. Unpin all but the most recent one that you’ve booted into and used without issue. Then restart the PC. If you don’t boot into the latest image with the other having been cleared use the following command to clear those out.
rpm-ostree cleanup -r
Thank you, this was the issue indeed!
It’s solved now.
