Initial setup in desktop mode
Hello.
When I first started bazzite on the desktop I accidentally skipped the initial setup (those windows where you choose the plugin, additional applications, etc.) is it possible to restart, re-run this setup?
Yes, as often as you want! It’s called “Bazzite Portal” in the Apps.
