I would like to customize my RGB
Hello, I’m not sure if I can find help here; I don’t see a suitable tag.
I don’t understand English very well, so I’m using Google Translate.
I just installed Bazzit and so far everything is working correctly, but I’m coming from Windows and I can’t find the software that allows me to change the RGB colors of my Fusion RGB RAM stick. So I installed OpenRGB, and things get complicated when it asks me to install an openrgb-udev-install.sh script.
This isn’t something I usually do.
Not sure how you were trying to install OpenRGB, but you can install it from the Bazzite Portal app; that shouldn’t prompt you to run any shell scripts apart from anything it might need to run automatically. I didn’t run into any complications when doing it that way.
hello
I install the apps with Bazaar; I don’t know if that’s correct since it’s provided by default, but yes, your method didn’t ask me to install anything else.
thanks
