HP Z600 workstation
I have a HP Z600 with dual Zeon 3.06 6core 12thread CPU’s. The question is will Bazzite work with both CPU’s Machine specs are 48Gigs ECC 10600 ram a Strix 570 8Gig video card. It is currently running Linux mint 20.
I’d like to try bazzite on it so it can be used as a gaming machine. As I’ve had it for quite sometime and it has been very reliable. I’m thinking it would a fun gaming machine. I do not expect it to play the latest games, just the few I like to play.. when its using both CPU’s you could say its like having a 12core 24thread machine. any answers/help will be greatly appreaciated
I assume this something like an LGA 2011v2 machine?
Will work perfectly fine, Linux has better multi-thread schedulers anyway.
I already built a machine using Xeon 2011v2 CPU’s on a cheap no-name Chinese motherboard tested with a RX 580, a RX 6600 and a Intel A770, it works flawlessly with Bazzite, better than Windows 10 to be honest as everything works right out of the box, also if you still want to retain it as a workstation, there is Bazzite-DX you could try as well.
I also forgot to add, there is a Live boot image now too, so you can fire it up and test it out without impacting your current install of Mint.
Download page: Bazzite – The next generation of Linux gaming
