How to transfer a ublue install to another drive?
I think this is a common problem and it is currently not documented.
How do I move a ublue install to another disk?
I suppose using clonezilla would work, but is there a more elegant solution, seeing that it is image based?
Like create stub partitions / BTRFS volumes and copy the files, install the OS fresh with exported overrides
I’m not sure there’s anything to document, you’d do a redeployment from scratch since it’s much faster to just copy the user data over?
You could try the methods you mentioned and report back if you think it’s useful perhaps?
