Hello, new to the forum here (and a bit unsure if the tags match my problem), anyway to cut to the chase, I need help in knowing how I can get vlc to play my blur-ray and 4k discs as whenever I insert the disc and try to play it, vlc states there’s missing aacs configuration files. I do have the libbaacs stuff but I don’t know what to do with it.
Any help will be much obliged
Hi @Dane_Blue, welcome!
Get the latest KEYDB.cfg file from one of these sources:
mkdir -p ~/.var/app/org.videolan.VLC/config/aacs/
mv /path/to/downloaded/KEYDB.cfg ~/.var/app/org.videolan.VLC/config/aacs/
Grant VLC Flatpak Permissions
By default, Flatpak apps run in a sandbox with limited access. Grant VLC Blu-ray drive access:
flatpak override --user --filesystem=/dev/sr0 org.videolan.VLC
If your Blu-ray drive has a different path, replace /dev/sr0 with the correct one (use lsblk to check).
: Disable Blu-ray Menu in VLC
- Open VLC.
- Go to
Tools → Preferences.
- Click
Show All (bottom-left corner).
- Search for
Blu-ray.
- Uncheck
Menu.
- Save & Restart VLC.
Play Blu-ray Disc
Run VLC from the terminal with:
flatpak run org.videolan.VLC bluray:///dev/sr0
Troubleshooting
- If Blu-ray doesn’t play, update
KEYDB.cfg from the sources above.
- If VLC can’t detect the Blu-ray drive, grant more permissions:
flatpak override --user --filesystem=host org.videolan.VLC
- If VLC still fails, check logs for missing dependencies:
flatpak run --command=sh org.videolan.VLC -c "vlc -vvv bluray:///dev/sr0"
Thanks for the information
