How to configure automatic updates
Warning: Disabling automatic updates is an unsupported configuration.
Commands
The following just commands enable and disable the appropriate services:
  • ujust toggle-updates
Manually (Main images)
You can individually disable which automatic update timers ublue-os/config provides with the following commands:
  • flatpak system: sudo systemctl disable flatpak-system-update.timer
  • flatpak user: sudo systemctl --global disable flatpak-user-update.timer
You can also configure automatic rpm-ostree updates by editing /etc/rpm-ostreed.conf and changing “AutomaticUpdatePolicy” to “none” or “check”:
[Daemon]
AutomaticUpdatePolicy=check
Manually for Bazzite and Bluefin/Aurora
Bazzite and Bluefin use ublue-update, which you can enable and disable with the following commands:
  • systemctl disable ublue-update.timer - Disable automatic updates
  • systemctl enable ublue-update.timer - Enable automatic updates
Note that this timer handles the following components:
  • Flatpaks
  • Brew packages
  • Containers used by distrobox
  • VS Code extensions
and a variety of other components depending on what you install. Manual configuration of can be configured via /usr/share/ublue-os/topgrade.toml.
Check the topgrade for more features and options.
I tried first command and got this:
❯ just enable-updates
error: Justfile does not contain recipe `enable-updates`.
I tried with ujust also, the same
What I am doing wrong ?
I forgot to update this doc when the change landed, it’s ujust toggle-updates.
Here’s the file if you wanna see what it’s doing:
For automatic updates, are users prompted to confirm any changes to a flatpak’s permissions?
Nope - even if you run the updater manually, it just tells you about permission updates, it doesn’t confirm with you.
That’s a shame.
It seems like a bit of a security issue for flatpak updates to grant elevated permissions, without user notice or confirmation.
