How Do I Change An Icon?
Hi everyone,
I am using the latest stable build. When I try to change an icon, I get an error.
Is there any way to change my Chrome icon? I want to replace my father’s Windows 10 PC with Aurora, but he needs things as simple as possible, so I really want to change the Chrome icon to the Gmail icon.
Thanks!
I rushed to explain this with pictures, so it may seem a little messy. If there is any part of it you don’t understand, feel free to let me know.
I think a simpler solution may be for you to use the install application button within chrome to create shortcuts for each of the websites that you want to setup, as it’ll use the website logo automatically when you do it that way.
I ended up doing it via the menu editor. Got it working. Thanks everyone.
