I have a setup with an HDMI TV and a microphone, but whenever the system starts, be it in game mode or not, it goes back to my microphone as default playback.
Is there any way to set it to start already using the HDMI device as default?
I had to login to desktop mode, then go into the little kde sound settings, disable all the things that aren’t hdmi, then reboot back into game mode and then it was fine. I only had to do this once and the settings stick, but I wasn’t able to determine why it had ended up that way.
Thank you, I’ll try that when I get home!!!
I can confirm this behavior. Every time I plugged in the DualSense, the controller was set as the main speaker. Disabling every speaker device through desktop mode except HDMI audio has fixed this. The others still show up, but Game Mode does not switch whenever I plug in the DualSense now
Chiming in to confirm.
Disabling the inputs and outputs that I do not use works for me.
Too bad I’m having problems with my Gaming Mode now, so I can’t test it. But at least on desktop mode it is working for me as well. Bazzite stopped switching to my microphone output on boot!!!
Thank you so much!!!
I’m only posting this in the perspective of non-deck version of Bazzite (i.e. no game/deck mode). I have a problem that Bazzite switches the default audio device to the onboard sound card when I starts a sunshine stream. I found that the order of audio device is determined by wireplumber. I have successfully set my desktop to use my HDMI monitor (actually connected via DisplayPort) as the default audio device without disabling the onboard sound card.
First, open a terminal, run wpctl status and note the ID next to each sink under Audio
k7so@bazzite:~$ wpctl status
Audio
├─ Devices:
│ 50. Renoir Radeon High Definition Audio Controller [alsa]
│ 51. Family 17h/19h HD Audio Controller [alsa]
├─ Sinks:
│ 53. Family 17h/19h HD Audio Controller Digital Stereo (IEC958) [vol: 1.00]
│ * 62. Renoir Radeon High Definition Audio Controller Digital Stereo (HDMI 2) [vol: 0.64]
├─ Sources:
│ 54. Family 17h/19h HD Audio Controller Analog Stereo [vol: 1.00]
├─ Filters:
└─ Streams:
Note that the ID for “Family 17h…” (my onboard sound card) is 53 and that for HDMI is 62.
Then, run wpctl inspect <id>, where <id> is the ID I mentioned above. Note the value for priority.driver and priority.session.
k7so@bazzite:~$ wpctl inspect 53
id 53, type PipeWire:Interface:Node
* node.description = "Family 17h/19h HD Audio Controller Digital Stereo (IEC958)"
node.driver = "true"
* node.name = "alsa_output.pci-0000_06_00.6.iec958-stereo"
* priority.driver = "736"
* priority.session = "736"
k7so@bazzite:~$ wpctl inspect 62
id 62, type PipeWire:Interface:Node
* node.description = "Renoir Radeon High Definition Audio Controller Digital Stereo (HDMI 2)"
* node.name = "alsa_output.pci-0000_06_00.1.hdmi-stereo-extra1"
* priority.driver = "632"
* priority.session = "632"
You can see that the priority for the onboard card is 736, while that for the HDMI is 632. As the onboard sound card has higher priority it will be preferred.
To fix this, we can add a config file to override the priority value for the onboard card.
Open Kate (the text editor), open a new file and paste the following contents:
monitor.alsa.rules = [
matches = [
actions = {
update-props = {
priority.driver = 500
priority.session = 500
In the config the part after node.name should match the node.name as shown in the wpctl inspect output. I change the priority from 736 to 500 so that it will be lower than that for my HDMI.
Save this file as /home/<your username>/.config/wireplumber/wireplumber.conf.d/51-deprio-onboard.conf. In other words, we put this file into the /home/<your username>/.config/wireplumber/wireplumber.conf.d/ directory (you need to create the intermediate directories yourself). And the name for the file is 51-deprio-onboard.conf (actually only the beginning 51- and file extension .conf matter, you can name the middle part to anything as you wish).
After placing that config file, run the command systemctl --user restart wireplumber to restart the wireplumber service.
Double check the priorities using wpctl status and wpctl inspect <id> (note that the ID will change after restarting wireplumber). You can see that the priority has been changed as desired.
Adapt this to your needs. Just remember that the priority should not be set to higher than 1500.
I believe that it should work in game mode too after editing this in desktop mode, as the creator of Bazzite said “steam game mode defaults to whatever Wireplumber’s configured default is”.
Reference: ZenLinux Blog » Blog Archive » How to Configure Audio Device Priorities in Pipewire / Wireplumber (However the configuration part is outdated)
Edit: I played around the sound setting a little more and found that the “Default Configured Devices” shown in wpctl status also matters. If there is the device that matches the default configured device, then that device should be chosen as the output. If not the device with highest priority will be chosen. It can be changed by wpctl set-default <id> or just by selecting that device in KDE.
Thank you so much. I followed your step-by-step guide, and it worked like a charm.
I’m not sure about gamemode yet, because it is not working for me due to hardware limitations. But at least in desktop mode it is fixed!!!
