Help with Intel MIPI IPU6 camera
Hi all. I installed BlueFin (stable channel) on my Dell XPS 13" 9315 which has the Intel MIPI IPU6 camera. With Chrome, the camera isn’t recognized by Google Meet at all. With FireDragon, the camera just takes a snap of me when the Google Meet starts and then displays the static image. Can anyone help me get it working consistently? Thx!
Hello, I have the same problem with a Dell Latitude 7440. I looked into the issue extensively, and its basically a Linux kernel problem due to the lack of Intel’s drivers. Some models might work depending on the sensor of your camera.
For now I simply use an external camera. Our best solution for now is to wait for a fix. There is currently a proposed change in Fedora aiming to add support for more sensors, targeting the Fedora 42 release, which should come around end of April.
