Hi liqudictl does NOT like my pump lights I had them saved to a certain color from previous windows install and now all they do is flash bright every second. How can I turn this off? I tried turning off pump control at startup. This is a fresh install. OpenRGB does nothing as well will not set the light settings for pump all the sudden.
Pump model is a corsair commander core hi100.
