The USB WiFi adapter is:
Panda Wireless PAU0D Dual Band (2.4GHz/5GHz) 802.11ac USB Adapter With Dual High Gain Antennas
It has: * Multi-OS support: 32-bit and 64-bit Windows 7/8/10/11/2019/2022, Zorin, MXLinux, EndeavourOS, Mint, Manjaro, Ubuntu, Lubuntu, Kubuntu, Pop!_OS, Fedora, Rocky, Debian, Arch Linux, openSUSE, Kali Linux, Tails, Raspbian and Puppy. NO Mac support for Panda Wireless PAU0D.
I can confirm as I used on Fedora Spin KDE and Linux Mint with no issues.
I just installed Bazzite onto my Desktop PC. I do not have an ethernet that can connect to my PC. I have an AMD Radeon RX 6600. I do not have Windows on the machine this is a fresh install onto the SSD.
What I picked when downloading the ISO:
What hardware are you using?
- Desktop
Who is the vendor of your primary GPU?
- AMD (RX 4xx+)
What desktop environment do you prefer?
- KDE (Like SteamOS)
Do you want Steam Gaming Mode?
- Yes
When I installed Bazzite from the installation screen on USB, it detected my USB WiFi adapter and allowed me to connect to my router. However, after the installation, it no longer seems to be able to find any networks.
This is all I see:
I’ve also restarted my PC. I went into the About settings and hit the factory reset button twice. Finally, I unplugged my USB WiFi adapter and plugged it back in.
