I’m running Bluefin Asus version using the latest image and this issue during the update keeps coming up. I’m unsure what to do with it. Recommendations are appreciated.
You don’t need to do anything, it means that the Clapper app (the video player) needs to be updated to the latest GNOME runtime, which isn’t something end users do. The clapper folks are working on it.
TL;DR:
But… if you want:
The same issue as some user and I have had like month ago. You can probably safely remove KDE runtime 6.6, because it looks like obsolete, but just in case see System Flatpak Runtimes EOF for details.
For Gnome 45 runtime and looking at upstream Clipper bug tracker, they are already working on this fix, but it looks like program is having some issue with newer runtimes.
