Hi All,
I’m trying to get a TP-Link Wifi Adapter TL-WN821N to work on bazzite.
I found this suggested solution on Grok:
Best option: Use the DKMS-enabled driver from GitHub (supports modern kernels, auto-rebuilds on updates).
sudo apt update
sudo apt install build-essential dkms git linux-headers-$(uname -r)
git clone https://github.com/Mange/rtl8192eu-linux-driver.git
cd rtl8192eu-linux-driver
sudo dkms add .
sudo dkms install rtl8192eu/1.0
This resulted in the following:
Darren@bazzite:~$ sudo apt update
[sudo] password for Darren:
sudo: apt: command not found
Darren@bazzite:~$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 214b:7250 Huasheng Electronics USB2.0 HUB
Bus 003 Device 004: ID 046d:c534 Logitech, Inc. Nano Receiver
Bus 003 Device 005: ID 3151:3022 YICHIP Wireless Device
Bus 003 Device 006: ID 0bda:8178 Realtek Semiconductor Corp. RTL8192CU 802.11n WLAN Adapter
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 004 Device 002: ID 0080:a001 Unknown JMS578 based SATA bridge
Bus 004 Device 003: ID 1f75:0621 Innostor Technology Corporation IS621 SATA Storage Controller
Darren@bazzite:~$
The sudo command shows as an unknown command.
Your Help would be greatly appreciated.
Cheers and Beers Gelignite
