How can I change the behavior of the lid of my Z13 in gamescope mode?
Currently it wakes up from sleep mode when I close the lid and pressing the power button with the lid closed does nothing.
Help is appreciated.
Have you gone into the desktop mode and made adjustments in the power section of the settings app?
Features in there mostly carry over to Gamescope.
On a side, how is the Tablet? I really want one of these, looks like an awesome machine.
I have made the adjustments in desktop mode but unfortunately, no difference.
The Flow Z13 2025 is insane. It’s very expensive but it also can easily replace your gaming pc, laptop and handheld pc.
The battery is decently sized but could be a bit bigger though, as you’ll barely get 2 hours out of it playing games at 20 Watt TDP. The total system power draw is just much higher than comparable handheld pcs like the Ally X at the same TDP.
