Flameshot stopped working for me
Flameshot has stopped working, saying it cannot capture the screen.
As best I can tell, it worked on 2024-11-08, if not later.
❯ flatpak run org.flameshot.Flameshot gui
Gtk-Message: 11:51:12.231: Failed to load module "canberra-gtk-module"
Gtk-Message: 11:51:12.232: Failed to load module "canberra-gtk-module"
qt.qpa.qgnomeplatform: Could not find color scheme  ""
Qt: Session management error: Could not open network socket
flameshot: error: Unable to capture screen
flameshot: info: Screenshot aborted.
I rolled back to the 2024-11-12 release, but it still fails. I’m not sure if this is when it broke, but has worked recently.
Even thought it worked previously, I’ve fiddled around with FlatSeal, but nothing seems to help.
Here’s my system info (still booted from 2024-11-12)
❯ neofetch --logo none
  john@beast
󱋩  bluefin-dx-nvidia:stable 🔐
󰣛  Bluefin-dx 41 (FROM Fedora Silverblue)
  Linux 6.11.3-300.fc41.x86_64
󰅐  5 mins
󰔠  Forged on Sep 02 2024
󰻠  13th Gen Intel(R) Core(TM) i9-13900K (32) @ 5.80 GHz
󰍛  NVIDIA RTX A4500
󰍛  Intel Arc A380 @ 2.45 GHz [Discrete]
󰧑  25.68 GiB / 125.48 GiB (20%)
  708.93 GiB / 1.82 TiB (38%) - btrfs [Read-only]
  2.69 TiB / 4.55 TiB (59%) - btrfs
  22.83 TiB / 42.16 TiB (54%) - zfs
󰍹  3840x2160 @ 60 Hz in 27" [External]
󰍹  2560x2880 @ 60 Hz in 28" [External] *
󰖺  stream-controller-os-plugin
󰕮  GNOME 47.1
  Mutter (Wayland)
  zsh 5.9
  Ptyxis 47.3
󰏖  2290 (rpm), 76 (flatpak), 203 (brew)
❯ rpm-ostree status
State: idle
Deployments:
  ostree-image-signed:docker://ghcr.io/ublue-os/bluefin-dx-nvidia:stable
                   Digest: sha256:caed93ec81c47fbed510cc9552a2c912e1c8a19080eaf8ef8366fec4c7d38422
                  Version: 41.20241117.3 (2024-11-17T15:51:24Z)
                     Diff: 143 upgraded, 2 removed, 1 added
            LocalPackages: 1password-8.10.40-1.x86_64 gnome-clocks-46.0-1.fc40.x86_64
● ostree-image-signed:docker://ghcr.io/ublue-os/bluefin-dx-nvidia:stable
                   Digest: sha256:b7e5c76158f15ad0496b607ea18da6eac57d1de694884451e5034d8071db8a2e
                  Version: 41.20241112.1 (2024-11-12T21:11:32Z)
Thanks for any suggestions!
~ ❯ flatpak run org.flameshot.Flameshot gui
~ ❯ flatpak permission-set screenshot screenshot org.flameshot.Flameshot yes
After setting that permission it worked on my system. Before it did not like on your system.
Just a fresh flatpak install so didn’t mess with anything other then that. Hope that works for you.
Thanks! :raised_hands:
One step closer.
Does the keyboard work for you? i.e. press Ctrl-s to save, or Space for settings?
Doesn’t work for me.
Yep seems like it, captured with keyboard shortcut :smiley:
Yeah keyboard worked fine, was able to open the panel with space, change color and draw on my screenshot and save it with ctrl-s to disk.
Saw something about Clapper and pinned kde and gnome things that were out of date, decided to remove the flatpak.
Did a ujust update and reboot again, and everything is working now.
:person_shrugging:
Thanks again!
