Filesystem is very dificult to understand for me, and apps have problems too, it seems
I mentioned the problem to navigate in the filesystem in a previous question:
Information wanted about file-system and search function I didn’t find an answer to that question.
Now, I have a USB-disk , it’s at run/media/myname/USBdisk
But if try to find that disk with, for instance Puddletag, I don’t have that media directory. I gave Puddletag more permissions with Flatseal, but that didn’t help.
Where the fudge can I find all those directories??
(Puddletag is not the only app that didn’t see my usb-disks).
I haven’t used Puddletag, but I use a lot of flatpaks and haven’t noticed any issue accessing mounted drives. I just launched VLC (from flatpak) and used it to open an MP3 on a usb mounted in a similar location to yours as a sanity check. No problems.
Can you get into the location you expect the drive to be using any means? Do you see it in a terminal command-line? In your DE’s file manager?
Thank you for testing and for your feedback!
Dolphin sees the drive and folders, Clapper (media player) sees them, system sees them.
And like I said, it’s not only Puddletag (it was another tag-application, that’s why I switched) I can open the files on the drive with Puddletag tough.
❯ sudo fdisk -l
Device     Boot Start        End    Sectors   Size Id Type
/dev/sda1        2048 1953522112 1953520065 931,5G  7 HPFS/NTFS/exFAT
Anyway, maybe I’ll have to come back to this when I experience it again with another program…
Correction: I use Nautilus, not Dolphin.
But anyway, I installed Rhythmbox and that couldn’t see my usb-drive either, until I changed permissions with Flatseal. I allowed it to reach input-devices and that did the trick.
I don’t know if the warningsign is important?
The warning sign just shows that it’s a setting the user has modified, it’s nothing to worry about!
