Export items from toolbox
Hello, I’m trying to install Alacritty. It’s not available as a flatpak or through homebrew. I can easily install it in a toolbox with dnf, but can’t access it as a desktop item.
What is the preferred way of doing something like this on bluefin?
Thanks in advance
Using distrobox,
Enter your container and type:
distrobox-export --app alacritty
Docs:
If you want to use GUI instead, you can start BoxBuddy, select your container and click on View Applications. Then click next to application on Add To Menu button.
