I installed npm via brew and when I run ujust update I get the following errors:
── 11:26:07 - Node Package Manager ─────────────────────────────────────────────
(node:78457) ExperimentalWarning: CommonJS module /var/home/linuxbrew/.linuxbrew/lib/node_modules/npm/node_modules/debug/src/node.js is loading ES Module /var/home/linuxbrew/.linuxbrew/lib/node_modules/npm/node_modules/supports-color/index.js using require().
Support for loading ES Module in require() is an experimental feature and might change at any time
(Use `node --trace-warnings ...` to show where the warning was created)
npm error code EEXIST
npm error syscall symlink
npm error path ../../../lib/node_modules/npm/man/man7/package-spec.7
npm error dest /var/home/linuxbrew/.linuxbrew/share/man/man7/package-spec.7
npm error errno -17
npm error EEXIST: file already exists, symlink '../../../lib/node_modules/npm/man/man7/package-spec.7' -> '/var/home/linuxbrew/.linuxbrew/share/man/man7/package-spec.7'
npm error File exists: /var/home/linuxbrew/.linuxbrew/share/man/man7/package-spec.7
npm error Remove the existing file and try again, or run npm
npm error with --force to overwrite files recklessly.
npm error A complete log of this run can be found in: /var/home/guru/.npm/_logs/2024-11-09T16_26_07_802Z-debug-0.log
Any ideas?
