Digital Microphone Stuck in SUSPENDED State on FW 13 (Bluefin GTS)
Issue Summary
Hi everyone, I’m experiencing an issue with my new Framework Laptop 13 (DIY Edition) running Bluefin GTS, where my Digital Microphone (Mic1) is detected but remains in a “SUSPENDED” state and won’t activate consistently.
What I’ve Tried So Far
  • The microphone is recognized by PipeWire but stays unavailable.
  • pactl list sources shows Mic1 but labels its availability as “unknown”.
  • I was briefly able to record using Mic1, but the success wasn’t persistent—it reverted to SUSPENDED afterward.
  • Switching audio profiles (pactl set-card-profile 43 "HiFi (Mic1, Mic2, Speaker)") didn’t resolve the issue.
  • PipeWire logs suggest modules aren’t loading properly, showing errors like:
pw.context: no modules loaded from context.modules
pw.conf: can't find factory adapter
default: failed to create context: No such file or directory
  • Reinstalling PipeWire (dnf remove/install pipewire wireplumber) didn’t change the behavior.
Additional Issue: Overheating Concerns
Yesterday, I experienced major overheating (100°C) on my laptop during testing of Google Meet, which I downloaded from Software Center. While I haven’t reproduced it today, it’s possible that thermal issues are affecting the microphone or other components. Below is my current sensor output after 3 hours of uptime:
cros_ec-isa-0000
Adapter: ISA adapter
fan1:               0 RPM
local_f75303@4d:  +44.9°C
cpu_f75303@4d:    +48.9°C
ddr_f75303@4d:    +38.9°C
cpu@4c:           +52.9°C
(Sensors output continues…)
Of course, I installed Bluefin as soon as I could :slight_smile: ! I used the recommended Anaconda installer. I had some pre-booting warning messages but after I installed Secure Boot, I no longer have any pre-booting warning messages.
System Details Report
Report details
  • Date generated: 2025-05-12 09:09:05
Hardware Information:
  • Hardware Model: Framework Laptop 13 AMD Ryzen AI 300 Series
  • Memory: 64.0 GiB
  • Processor: AMD Ryzen™ AI 9 HX 370 w/ Radeon™ 890M × 24
  • Graphics: AMD Radeon™ Graphics
  • Disk Capacity: 2.0 TB
Software Information:
  • Firmware Version: 03.03
  • OS Name: Bluefin (Version: gts-41.20250511 / FROM Fedora Silverblue 41)
  • OS Build: ea35c6a
  • OS Type: 64-bit
  • GNOME Version: 47
  • Windowing System: Wayland
  • Kernel Version: Linux 6.13.8-200.fc41.x86_64
  • Audio Stack: PipeWire with WirePlumber
  • Current Default Microphone: Family 17h/19h/1ah HD Audio Controller Digital Microphone
  • Active Card Profile: HiFi (Headset, Mic1, Speaker)
  • Output from pactl list cards:
Card #42
Active Profile: off
Card #43
Active Profile: HiFi (Headset, Mic1, Speaker)
Questions for the Community:
  1. Could this be a missing firmware issue?
  2. Is there a Bluefin-specific PipeWire configuration that might be affecting this?
  3. Has anyone encountered similar microphone issues with Framework laptops?
  4. Could my overheating issue be linked to the microphone issue?
  5. Any deeper debugging suggestions for PipeWire or ALSA that I should try next?
Update 1:
Here is a reproducible test to get Mic1 working temporarily:
  1. Verify PipeWire sees the microphone:
pactl list sources | grep -A 10 'Source #52'
Because Source 52 is listed, but remains SUSPENDED, proceed to the next step.
  1. Manually start a recording session (this forces activation):
arecord -D hw:0,0 -f S32_LE -r 48000 -c 2 -d 5 test.wav
Then, play back the recorded audio:
aplay test.wav
  1. Check if Mic1 stays active after recording:
Because If it reverts to SUSPENDED afterward, this confirms PipeWire is not keeping it active.
It proves that the microphone itself works, meaning the issue is likely software-related. Unless maybe it is related to the DIY Bezel installation?
Update 2:
Fedora 42 Live: Audio works perfectly (one sound bar, no crashes).
Bluefin:
  1. Two sound bars appear (one mute, one active).
  2. Audio mutes randomly until reboot.
  3. Logs show "error": null spam (14x).
Question: Known fix for the dual sound bar bug?
Update 3:
Another FW13 user has the internal microphone issue:
https://community.frame.work/t/solved-headset-mic-on-amd-fw13-running-fedora-39/38847/24
Another FW13 user has the high temperature issue:
https://community.frame.work/t/cpu-boiling-during-heavy-use-compilation/68967/12
I can confirm this issue on my Laptop 13 with AMD Ryzen AI 7 340 using Bluefin DX stable 42.20250601.1
Confirmed: Bluefin GTS 05252025 Update Fixed Mic Issues
After thorough testing, both internal microphones now work reliably after reboots:
  • Analog (ALC285): arecord -D hw:0 -f S16_LE -r 48000 -c 2
  • Digital (ACP): pw-record --target=alsa_input.pci-0000_c1_00.6.HiFi__Mic2__source
Root Cause: The 05252025 update resolved critical AMD ACP firmware and PipeWire integration issues. Minor manual tuning (sample rate/target selection) was needed for optimal performance.
Notes:
  • External microphones: Untested—focus here was on internal hardware.
  • Future improvements: Ideally, Bluefin could auto-detect optimal settings to avoid manual tuning.
Quick test for digital mic (record + play):
pw-record --target=alsa_input.pci-0000_c1_00.6.HiFi__Mic2__source test.wav
aplay test.wav
After updating to stable-daily 42.20250605 I can confirm that the analog mic is working now, but I still cannot get the digital microphone to work and it still happens, that when I select the analog mic in gnome settings, than the speaker output device disappears.
I’m seeing the same thing in DX (42.20250914.1). Analog seems to be working once I changed to it, but still not digital.
Thanks for the update. I wonder: Is this sound issue resolved in LTS or LTS-HWE? It sounds like GTS now (from September 18, 2025) directly will compete will LTS and LTS-HWE. I’m not sure myself yet. My limited understanding is that all Framework devices for Bluefin should default to LTS-HWE – not GTS or LTS.
