Hello, I have been trying out bluefin and enjoy it, but I’m having trouble using devcontainers when I’m using tailscale with a mullvad exit node as VPN. No domain resolution happens within these containers. Distrobox (using podman I assume) works fine. I have tried turning off tailscale and devcontainers were able to use dns again. Is there a way to use devcontainers with the reccomended tailscale setup? Since tailscale is added to the image by default, this seems like a UX bug.
Did you enable lan access in tailscale?
tailscale set --exit-node-allow-lan-access
