It would be great if the default editor in aurora dx would be code —wait because it is installed anyway.
if that is not feasible it would be great to have docs which tell unseres where to change that. .profile doesn’t seem to be used.
That would be a bad idea.
Go to System Settings and search for Default Applications. Here you can set the Text Editor in section Documents.
