Deepfried artifacting on boot
New to ublue in general so bear with me.
When booting into bazzite from shutdown (cold booting?) i get this weird deep-fried look
It goes away immediately after it detects mouse movement, both regular mouse and controller mouse, or when i exit the SteamUI (desktop or launching game).
I made sure that it was a consistent issue by shutting down and booting up multiple times and it persisted. It does not have this issue when rebooting, only when booting from shutdown.
The issue has not affected the KDE desktop, as when I used the Steam power menu to go to desktop, everything was fine.
My current theory is that it’s an issue with the Steam client, but i thought it was worth mentioning to the Bazzite ublue group in case anyone has faced a similar problem
I am running the Bazzite-deck image (I don’t remember how specifically check for the version), the hardware is:
12th gen intel i5-12600k
AMD Radeon RX 7600 XT
32 GB DDR5 ram
ASRock Z790M-ITX (mobo)
The issue might be related to the July 16th Steam client update, as i installed that shortly before this started happening, but i didn’t notice it because I was dealing with something on desktop then shut down for a few hours
Any help is appreciated
I will try to also report this to valve in case the issue is on their end
Steam deck client update has resolved the issue
for now
