Deck Gamemode on Ultrawide Monitor?
I installed Bazzite deck edition on a second nvme in my workstation. I have an ultrawide monitor and game mode does not set the correct aspect ratio. Is this a known problem, or is there a workaround for this?
Seems to be a known issue without a definite workarounnd. In my case, I’m running on a Steam Deck. The display settings were for the internal display even when I was docked and only have my external active. I switched to desktop mode then back to gaming mode to have it show the external in display settings instead. Then I had to uncheck the “automatically set resolution” toggle and manually choose an ultrawide resolution. UI was way to large at that point so I manually had to turn the scaling all the way down too.
