DaVinci Resolve - empty preview
The installation of Resolve worked great through ujust install-resolve - it also launches just fine - awesome!
But it seems like, no matter which format/codec i try to convert (eg: mkdir transcoded; for i in .MP4; do ffmpeg -i “$i” -vcodec mjpeg -q:v 2 -acodec mp3 -q:a 0 -f mov "transcoded/${i%.}.mov"; done ) my MP4 file from GoPro to - the preview field remains blank - and nothing happens when i hit play. I have tried with both 8 and 10 bit files, no difference.
The file tested here, work just fine when playing in Haruna.
I can help but wonder if there is some silly setting i need to change in Resolve, a missing codec i need to install or some VERY specific codec I should convert to.
Any suggestions would be welcome.
P.s. Kdenlive works just fine, but i would very much like to get Resolve working, as that is the one application i have not got working - and i really would love to leave Windows for good now.
I was only allowed to embed one image… so here the part missing:
I use AMD, and have set the following in Memory and GPU preferences:
Hi what is the video encoding format? H.264, AV1 etc? Davinci Resolve on Linux is very stingy when it comes to video encoding support. If I remember correctly, on AMD GPUs, H264 and H265 is not supported by default, for example.
Hi, thank you for writing back :slight_smile:
I did find a list of supported formats, and tried a good few that 1: is supported by the free version of Resolve in Linux and 2: is supported by AMD GPUs.
I found that as long a I use MP3 for audio, I sound be grand… I think that the audio format should work, as in the image in my post, when I opted for MP3, it does show an audio… histogram?
I then tried a few different video codecs such as DNxHR, mjpeg - but to no use - nothing plays in the project.
So I expect that I need to seek out a super specific combination of video and audio, for Resolve to accept it.
I am currently trying out Kdenlive, and it could maaaaybe be an alternative, if I have to give up on Resolve.
You can find a list of all supported formats here, so there is no need for trial and error.
I honestly couldn’t recommend Kdenlive more. I was introduced to Kdenlive the same way you did, out of necessity and can’t go back to any other editor now. Your mileage might vary, of course.
Basically, DaVinci is a PITA when it comes to Linux. They’re too picky with what they do and do not support. I hope you can find something that works for you. Have fun! :smiley:
I believe I found that list the other day, but moved on when they named the Linux section “Rocky Linux 8.6 (CUDA)” - nVidia and a different distro than I have.
But just gave it a shot, converted to some of the mentioned codecs (as i read it…), such as dnxhd/dnxhr_lb, rawvideo/yuv420p, prores_ks/yuv422p10le - no difference.
Just for fun, I tried to generate a test clip using ffmpeg -f lavfi -i testsrc=duration=5:size=1280x720:rate=25 -c:v mpeg2video -q:v 2 -c:a pcm_s16le test.mov - same issue.
If anyone can suggest something else to try using the script, for a test video - I’d love to try.
But yeah - at this point Kdenlive seems like the better (and only) option for me :man_shrugging: :slight_smile:
