Consider adding foo2zjs to the base image, small package important for maaany printers
I couldn’t make my HP Printer work with HPLIP (Filter failed), so I downloaded a PPD that used foo2zjs (I layered it), and it worked perfectly.
I think foo2zjs is a very small package and wouldn’t hurt adding it to the base image.
Thanks!
Thanks, in progress here! When this is merged it’ll show up in your next update.
