Cannot switch to devmode
I would like to test devmode on Aurora
```bash
$ ujust devmode
/run/user/1000/just/just-RJ3Kqb/toggle-devmode: ligne 58: /usr/lib/ujust/ujust.sh: Aucun fichier ou dossier de ce nom
Developer mode is currently disabled
Enable or Disable developer mode
/run/user/1000/just/just-RJ3Kqb/toggle-devmode: ligne 75: Choose: commande introuvable
jm@2a01cb01304d2141000000000000071e:~$ ls /run/user/1000/just/just-RJ3Kqb/
ls: impossible d'accéder à '/run/user/1000/just/just-RJ3Kqb/': Aucun fichier ou dossier de ce nom
## Sorry for the message in French : No file found
$ rpm-ostree status
State: idle
AutomaticUpdates: stage; rpm-ostreed-automatic.timer: inactive
Deployments:
● ostree-image-signed:docker://ghcr.io/ublue-os/aurora-nvidia-open:stable
                   Digest: sha256:4cbab859931639c47e580739cee45b099b8b45599518619d89288b6b1e24167c
                  Version: 43.20260106 (2026-01-06T02:11:20Z)
cannot switch because no file found :  /run/user/1000/just/just-RJ3Kqb/
Is devmode still supported ?? Thanks for help
We had a error on there. We have fixed it and it will be available shortly as an update.
Thanks for the report!
