What is bluefinbox-enter
It is not an alias to distrobox-enter
, which I thought it was at first
Are there any documentation about it?
Also, are there any documentation about how to use bluefin-cli
Is that with the distrobox
command, BoxBuddy, or is there something more straightforward?
malix@malix-pc ~ > bluefinbox-enter --help
distrobox version: 1.7.2.1.1
Usage:
distrobox-enter --name fedora-39 -- bash -l
distrobox-enter my-alpine-container -- sh -l
distrobox-enter --additional-flags "--preserve-fds" --name test -- bash -l
distrobox-enter --additional-flags "--env MY_VAR=value" --name test -- bash -l
MY_VAR=value distrobox-enter --additional-flags "--preserve-fds" --name test -- bash -l
Options:
--name/-n: name for the distrobox default: my-distrobox
--/-e: end arguments execute the rest as command to execute at login default: default malix's shell
--clean-path: reset PATH inside container to FHS standard
--no-tty/-T: do not instantiate a tty
--no-workdir/-nw: always start the container from container's home directory
--additional-flags/-a: additional flags to pass to the container manager command
--help/-h: show this message
--root/-r: launch podman/docker/lilipod with root privileges. Note that if you need root this is the preferred
way over "sudo distrobox" (note: if using a program other than 'sudo' for root privileges is necessary,
specify it through the DBX_SUDO_PROGRAM env variable, or 'distrobox_sudo_program' config variable)
--dry-run/-d: only print the container manager command generated
--verbose/-v: show more verbosity
--version/-V: show version
