Bluefin virt-manager read iso files with access denied
Impossible install virtual machines on Bluefin.
Virt-manager with access denied error on win11 iso.
ujust setup-virtualization error too: no works and no available.
How to solve this?
Virtualization tools are available in the dx variant, not the regular Bluefin as best as I can recall (you can double check by running virsh --version). You’d want to rebase to bluefin-dx (using ujust rebase-helper) to get virt tools. Once your system reboots, you can install VMs from ISOs via Virtual Machine Manager.
Or you can use the virt-manager flatpak with the QEMU extension. Although you will some of the passthrough features that the native version in -dx gives you.
