I’ve been loving LC3 support in windows, giving me low (enough) latency on common consumer headphones, no adapter required. On Bazzite, it’s still the old codecs. I tried enabling it via the instructions here: https://gitlab.freedesktop.org/pipewire/pipewire/-/wikis/LE-Audio-±LC3-support, and got things to pair. Unfortunately, once paired, the device appears to be recognized as an “Other” device with 0 battery life, and it does not appear as an audio device. should this be working? Did i do something wrong? I do recognize it’s labelled as experimental, but just wondering if the Mediatek card in there isn’t compatible.
Do you know if this is fully working on Fedora 43?
I think this is something the devs will need to integrate as the things that require editing are outside of the user space, and if they are not a thing that can be done easily on Fedora KDE yet, we may not see anyone even attempt it in Bazzite.
I 100% would love this feature as I use several Bluetooth headsets on a daily basis with Bazzite, any improvements on Bluetooth would be most welcome, maybe raise a feature request on Github and see if someone looks at it.
