Bazzite audio crackling
Hello, brand new to this forum and a recent bazzite user (LOVING IT). I am hitting my first real issue and wondering if there’s any known bugs/issues around it - my audio keeps crackling. This happens generally when there’s a bigger variation in volume, happens with both speakers and headset, in and out of games (most noticeable when listening to people talking on discord but not confined to that at all). I can consistently reproduce it with the “ding” when changing system volume as well. I can and will provide more specific information, but wanted to field the question more generally first to see if anyone could point me in a good direction.
Operating System: Bazzite 40
KDE Plasma Version: 6.2.0
KDE Frameworks Version: 6.7.0
Qt Version: 6.7.2
Kernel Version: 6.9.12-210.fsync.fc40.x86_64 (64-bit)
Graphics Platform: Wayland
Processors: 32 × AMD Ryzen 9 3950X 16-Core Processor
Memory: 62.7 GiB of RAM
Graphics Processor: AMD Radeon RX 6900 XT
Manufacturer: ASUS (custom build by me)
Speakers - Creative Stage v2 pro (USB)
Headset - Astro A50 (USB)
I have not messed too much with the audio subsystem (pretty novice to linux comparatively to many here I’m sure), just tried selecting different audio profiles (Analog, Digital Stereo, Pro) with differences in quality but no fix to this crackling issue. Any assistance is greatly appreciated, please let me know if I can provide additional information to help troubleshoot. Thank you!
Just occurred to me I could provide the information from “Info Center” for my audio devices, if helpful.
I got this issue too!
I’m curious if it has to do with pipewire? I’m not well versed on it though.
Hi everyone,
i do have the same issues especially with audio playback in Lollypop.
Games are mostly running fine and Discord was always a shitty mess.
I stumbled upon a reddit post suggesting to use xwayland instead of wayland natively.
For that i revoked the permission for wayland in flatseal.
Audio playback got a lot better but still not perfect. Only getting distortions if i wildly hover over tracks in my album. I read new pipewire package got a ton of fixes and the new Gnome 48 should be more performant as well - maybe next release might fix those issues?
Other suggested not using on-board audio but i still got those issues on my DAC as well.
My Specs:
Operating System: Bazzite 41
Gnome Version: 47
Kernel Version: Linux 6.13.7-108.bazzite.fc41.x86_64
Processors: 16 × AMD Ryzen 7 5700G 8-Core Processor
Memory: 32 GB of RAM
Graphics Processor: AMD Radeon RX 6950 XT
Manufacturer: MSI (custom build by me)
Speakers - Creative Inspire 5100ish (On-Board)
Headset - beyerdynamic DT880 Pro (hooked on USB DAC Fiio K5 Pro)
I believe there has been a github issue for this for a while, as well. Will link that here. Hopefully it’s relevant. Audio stuttering in many games in Gamescope w/ 6700XT · Issue #851 · ublue-os/bazzite · GitHub
cool, thank you for sharing the link.
It seems that there are many factors to consider. Most people using DACs are not hit by the issue.
The majority is facing issues with HDMI audio. As mentioned in the posts on reddit and github the kernel args are already present on bazzite.
Some suggest to configure pipewire further.
For now running my audio player through xwayland seems to work most of the time.
That whole issue is really strange, when i started using bazzite in december last year i had no issues.
I agree, I’ve been fine on stock Nobara or my previous openSUSE install but specifically Bazzite seems to have this issue for me.
So guys, after Updating to the newest bazzite release it seems to work now and doesn’t distort even if i hover over album lists in Lollypop - but i think audio has a long way to go on Linux. It feels like there ism a copious amount of performance held back due to the structure of the linux audio stack. At least with Pipewire it is in a usable state by now.
I remember times, running kvm pci-passthrough to a windows vm to run all these devices due to incomplete support on linux. We came a long way and thats freaking awesome!
Downloading bazzite → putting it on a disk → installing → simply use it
I found a solution to this issue. The easiest way to fix this issue is to install opencode on your Bazzite OS and instruct it to fix the audio crackling. There are so many settings related to audio that I had one setting correct but missed one. The opencode AI looked at all settings and corrected all settings.
In my case, this was the problem:
Root cause: snd_hda_intel codec power saving (power_save_controller=Y). Even though power_save=0 was set, the controller was allowed to power down the Realtek ALC257 codec during idle. When audio resumes after a quiet period, the codec takes time to wake up, causing the initial crackling you hear “after using it for a while.”
Secondary factor: CPU governor on powersave across all 32 threads of your i9-14900HX. Under load this can starve the PipeWire real-time thread, causing buffer underruns (xruns). The PipeWire quantum was also at the default low value (1024 frames / ~21ms).
Fixes Applied
Fix File Effect
Disabled snd_hda_intel power saving permanently /etc/modprobe.d/audio-fix.conf Prevents codec from sleeping; active immediately + after reboots
Increased PipeWire buffer (quantum 1024->2048, min 32->1024) ~/.config/pipewire/pipewire.conf.d/99-fix-crackling.conf Larger audio buffer reduces xruns; active now
Applied power_save_controller=N at runtime sysfs (live) Takes effect immediately without reboot
I was using claude AI to try and fix the issue and it found one problem but it can’t interact with the OS directly so it missed the other fixes. Bazzite seems to have quite a few settings related to power saving mode.
Once I installed opencode and let the AI fix the issues, my audio issues were instantly resolved. I was having constant crackling issues after using the OS for a while and had to reboot to get rid of it. Since having opencode fix all settings, audio has been working flawless and I haven’t rebooted in over a week.
I highly recommend installing and using opencode. I have used it for everything from fixing my audio issues to setting up WEBDAV folders, SSH, etc. It makes everything so easy on Linux because the AI has core access to your OS and can fix or setup anything effortlessly.
Without it, I would have never been able to fix this audio issue.
