Aurora or Bluefin
what happened to the updates on the Aurora distro ,
Nothing, they are running fine.
Did you layer some package? Check: rpm-ostree status and if some package is layered it is most probably the cause of the issue. Unlayer all packages, update the system and layer packages again.
