Adding a USB Scanner
Hello,
I have an old USB scanner (Fujitsu ScanSnap S1100i) which I’d like to use with my Framework laptop running Bluefin.
The output for sane-find-scanner is:
found possible USB scanner (vendor=0x04c5 [FUJITSU], product=0x1447 [ScanSnap S1100i]) at libusb:003:006
But the scanimage -L command doesn’t identify it:
No scanners were identified. [...]
I can see that the epjitsu.conf configuration file in the /etc/sane.d lists the driver for my scanner:
# Fujitsu S1100i
firmware /usr/share/sane/epjitsu/1100i_0A00.nal
usb 0x04c5 0x1447
Is anything else I should do to get the scanner working with the bundled “Document Scanner” app? It was working fine with a mutable Linux distribution.
