Active Users Graph is wrong
Hello, I think there is a major issue with the Active Users Graph on the Bazzite website.
Today’s graph :
Graph from 04/25 (taken from here) :
If you look at the numbers, you can see that they’re not the same.
Colonne 1 Today’s graph Graph from 04/25
02/25 12k 23k
03/25 13k 26k
04/25 14k 28k
If you use the numbers provided here, there was 26.3k users in 02/2025. But if you look at the graph from today, it says that there was 12k users at this time, which is wrong.
Ohh is it because of this ? So the current graph is correct ?
Yeah we were over-counting at the time, the current numbers should be correct now.
