Hey everyone,
I have a custom script for setting up samba and wsdd that I’ve been using on my regular Fedora setups, and it works flawlessly. Now, I want to make it work on Bluefin/Silverblue, but I’m not sure how to go about converting it. Any tips or guidance would be greatly appreciated!
My script:
#!/bin/bash
# Tolga Erok
# My personal Fedora 39 KDE tweaker
# 18/11/2023
# Run from remote location:
# sudo bash -c "$(curl -fsSL https://raw.githubusercontent.com/tolgaerok/tolga-scripts/main/CUSTOM-SCRIPTS/SETUP-SAMBA-WSDD/setup-samba-wsdd-users-folders-groups.sh)"
# ¯\_(ツ)_/¯
# https://github.com/massgravel/Microsoft-Activation-Scripts
clear
# Check if the script is run as root
if [ "$EUID" -ne 0 ]; then
echo "Please run this script as root or using sudo."
exit 1
fi
[ ${UID} -eq 0 ] && read -p "Username for this script: " user && export user || export user="$USER"
# Assign a color variable based on the RANDOM number
RED='\e[1;31m'
GREEN='\e[1;32m'
YELLOW='\e[1;33m'
BLUE='\e[1;34m'
CYAN='\e[1;36m'
WHITE='\e[1;37m'
ORANGE='\e[1;93m'
NC='\e[0m'
YELLOW='\e[1;33m'
NC='\e[0m'
echo '[charm]
name=Charm
baseurl=https://repo.charm.sh/yum/
enabled=1
gpgcheck=1
gpgkey=https://repo.charm.sh/yum/gpg.key' | sudo tee /etc/yum.repos.d/charm.repo
sudo yum install gum -y
clear
# Function to display messages
display_message() {
clear
echo -e "\n Tolga's SAMBA & WSDD setup script\n"
echo -e "\e[34m|--------------------\e[33m Currently configuring:\e[34m-------------------|"
echo -e "|${YELLOW}==>${NC} $1"
echo -e "\e[34m|--------------------------------------------------------------|\e[0m"
echo ""
gum spin --spinner dot --title "Stand-by..." -- sleep 1
# Function to check and display errors
check_error() {
if [ $? -ne 0 ]; then
display_message "[${RED}✘${NC}] Error occurred !!"
# Print the error details
echo "Error details: $1"
gum spin --spinner dot --title "Stand-by..." -- sleep 8
fi
# Template
# display_message "[${GREEN}✔${NC}]
# display_message "[${RED}✘${NC}]
## Networking packages
sudo dnf -y install iptables iptables-services nftables
sudo dnf -y install wsdd
## System utilities
sudo dnf -y install bash-completion busybox crontabs ca-certificates curl dnf-plugins-core dnf-utils gnupg2 nano screen ufw unzip vim wget zip
display_message "[${GREEN}✔${NC}] Installing SAMBA and dependencies"
# Install Samba and its dependencies
sudo dnf install samba samba-client samba-common cifs-utils samba-usershares -y
# Enable and start SMB and NMB services
display_message "[${GREEN}✔${NC}] SMB && NMB services started"
sudo systemctl enable smb.service nmb.service
sudo systemctl start smb.service nmb.service
# Restart SMB and NMB services (optional)
sudo systemctl restart smb.service nmb.service
# Configure the firewall
display_message "[${GREEN}✔${NC}] Firewall Configured"
sudo firewall-cmd --add-service=samba --permanent
sudo firewall-cmd --runtime-to-permanent
sudo firewall-cmd --reload
# Set SELinux booleans
display_message "[${GREEN}✔${NC}] SELINUX parameters set "
sudo setsebool -P samba_enable_home_dirs on
sudo setsebool -P samba_export_all_rw on
sudo setsebool -P smbd_anon_write 1
# Create samba user/group
display_message "[${GREEN}✔${NC}] Create smb user and group"
read -r -p "Set-up samba user & group's
" -t 2 -n 1 -s
# Prompt for the desired username for samba
read -p $'\n'"Enter the USERNAME to add to Samba: " sambausername
# Prompt for the desired name for samba
read -p $'\n'"Enter the GROUP name to add username to Samba: " sambagroup
# Add the custom group
sudo groupadd $sambagroup
# ensures that a home directory is created for the user
sudo useradd -m $sambausername
# Add the user to the Samba user database
sudo smbpasswd -a $sambausername
# enable or activate the Samba user account for login
sudo smbpasswd -e $sambausername
# Add the user to the specified group
sudo usermod -aG $sambagroup $sambausername
read -r -p "
Continuing..." -t 1 -n 1 -s
# Configure custom samba folder
read -r -p "Create and configure custom samba folder located at /home/fedora39
" -t 2 -n 1 -s
sudo mkdir /home/fedora39
sudo chgrp samba /home/fedora39
sudo chmod 770 /home/fedora39
sudo restorecon -R /home/fedora39
# Create the sambashares group if it doesn't exist
sudo groupadd -r sambashares
# Create the usershares directory and set permissions
sudo mkdir -p /var/lib/samba/usershares
sudo chown $username:sambashares /var/lib/samba/usershares
sudo chmod 1770 /var/lib/samba/usershares
# Restore SELinux context for the usershares directory
display_message "[${GREEN}✔${NC}] Restore SELinux for usershares folder"
sudo restorecon -R /var/lib/samba/usershares
# Add the user to the sambashares group
display_message "[${GREEN}✔${NC}] Adding user to usershares"
sudo gpasswd sambashares -a $username
# Add the user to the sambashares group (alternative method)
sudo usermod -aG sambashares $username
display_message "[${GREEN}✔${NC}] Restart SMB && NMB (samba) services"
# Set up SSH Server on Host
display_message "[${GREEN}✔${NC}] Setup SSH and start service.."
sudo systemctl enable sshd && sudo systemctl start sshd
display_message "[${GREEN}✔${NC}] Installation completed."
gum spin --spinner dot --title "Standby.." -- sleep 3
# Check for errors during installation
if [ $? -eq 0 ]; then
display_message "Apps installed successfully."
gum spin --spinner dot --title "Standby.." -- sleep 2
else
display_message "[${RED}✘${NC}] Error: Unable to install Apps."
fi
display_message "[${GREEN}✔${NC}] Setup Web Service Discovery host daemon"
echo ""
echo "wsdd implements a Web Service Discovery host daemon. This enables (Samba) hosts, like your local NAS device, to be found by Web Service Discovery Clients like Windows."
echo "It also implements the client side of the discovery protocol which allows to search for Windows machines and other devices implementing WSD. This mode of operation is called discovery mode."
echo""
gum spin --spinner dot --title " Standby, traffic for the following ports, directions and addresses must be allowed" -- sleep 2
sudo firewall-cmd --add-rich-rule='rule family="ipv4" source address="239.255.255.250" port protocol="udp" port="3702" accept'
sudo firewall-cmd --add-rich-rule='rule family="ipv6" source address="ff02::c" port protocol="udp" port="3702" accept'
sudo firewall-cmd --add-rich-rule='rule family="ipv4" port protocol="udp" port="3702" accept'
sudo firewall-cmd --add-rich-rule='rule family="ipv6" port protocol="udp" port="3702" accept'
sudo firewall-cmd --add-rich-rule='rule family="ipv4" port protocol="tcp" port="5357" accept'
sudo firewall-cmd --add-rich-rule='rule family="ipv6" port protocol="tcp" port="5357" accept'
# Define the path to the wsdd service file
SERVICE_FILE="/usr/lib/systemd/system/wsdd.service"
# Define the path to the old sysconfig file
OLD_SYSCONFIG_FILE="/etc/default/wsdd"
# Define the path to the new sysconfig file
NEW_SYSCONFIG_FILE="/etc/sysconfig/wsdd"
# Check if EnvironmentFile line with old path exists in the service file
if grep -q "EnvironmentFile=$OLD_SYSCONFIG_FILE" "$SERVICE_FILE"; then
# Comment out the old EnvironmentFile line
sudo sed -i "s|EnvironmentFile=$OLD_SYSCONFIG_FILE|#&|" "$SERVICE_FILE"
# Add the new EnvironmentFile line directly under the commented old line
sudo sed -i "\|#EnvironmentFile=$OLD_SYSCONFIG_FILE|a EnvironmentFile=$NEW_SYSCONFIG_FILE" "$SERVICE_FILE"
gum spin --spinner dot --title " Standby, editind WSDD config" -- sleep 2
# Reload systemd to apply changes
sudo systemctl daemon-reload
# Restart the wsdd service
gum spin --spinner dot --title " Standby, restarting , reloading and getting wsdd status" -- sleep 2
sudo systemctl enable wsdd.service
sudo systemctl restart wsdd.service
display_message "[${GREEN}✔${NC}] WSDD setup complete"
# systemctl status wsdd.service
sleep 1
echo "EnvironmentFile updated to $NEW_SYSCONFIG_FILE and service restarted."
sleep 2
else
# Check if EnvironmentFile line with new path exists
if grep -q "EnvironmentFile=$NEW_SYSCONFIG_FILE" "$SERVICE_FILE"; then
echo "No changes needed. EnvironmentFile is already updated."
else
# Add the new EnvironmentFile line at the end of the [Service] section
echo -e "\nEnvironmentFile=$NEW_SYSCONFIG_FILE" | sudo tee -a "$SERVICE_FILE" >/dev/null
sleep 1
echo "EnvironmentFile added with path $NEW_SYSCONFIG_FILE and service restarted."
sleep 2
fi
fi
# Old NixOS TCP & UDP port settings
allowedTCPPorts=(
21 # FTP
53 # DNS
80 # HTTP
443 # HTTPS
143 # IMAP
389 # LDAP
139 # Samba
445 # Samba
25 # SMTP
22 # SSH
5432 # PostgreSQL
3306 # MySQL/MariaDB
3307 # MySQL/MariaDB
111 # NFS
2049 # NFS
2375 # Docker
22000 # Syncthing
9091 # Transmission
60450 # Transmission
80 # Gnomecast server
8010 # Gnomecast server
8888 # Gnomecast server
5357 # wsdd: Samba
1714 # Open KDE Connect
1764 # Open KDE Connect
8200 # Teamviewer
allowedUDPPorts=(
53 # DNS
137 # NetBIOS Name Service
138 # NetBIOS Datagram Service
3702 # wsdd: Samba
5353 # Device discovery
21027 # Syncthing
22000 # Syncthing
8200 # Teamviewer
for port in "${allowedTCPPorts[@]}"; do
echo "Setting up TCPorts: $port"
sudo firewall-cmd --permanent --add-port=$port/tcp
done
for port in "${allowedUDPPorts[@]}"; do
echo "Setting up UDPPorts: $port"
sudo firewall-cmd --permanent --add-port=$port/udp
done
echo "[${GREEN}✔${NC}] Adding NetBIOS name resolution traffic on UDP port 137"
sudo iptables -t raw -A OUTPUT -p udp -m udp --dport 137 -j CT --helper netbios-ns
# Reload the firewall for changes to take effect
gum spin --spinner dot --title "Reloading firewall" -- sleep 1.5
display_message "[${GREEN}✔${NC}] Firewall rules applied successfully, reloading system services."
gum spin --spinner dot --title "Reloading all services" -- sleep 1.5
# Start Samba manually
sudo systemctl start smb nmb wsdd
# Configure Samba to start automatically on each boot and immediately start the service
sudo systemctl enable --now smb nmb wsdd
# Check whether Samba is running
sudo systemctl --no-pager status smb nmb wsdd
# Restart wsdd and Samba
sudo systemctl restart wsdd smb nmb
# Enable and start the services
sudo systemctl enable smb.service nmb.service wsdd.service
sudo systemctl start smb.service nmb.service wsdd.service
# Apply sysctl changes
sudo udevadm control --reload-rules
sudo udevadm trigger
sudo sysctl --system
sudo sysctl -p
sleep 1.5
display_message "[${GREEN}✔${NC}] Seek NETWORKED netbios names"
gum spin --spinner dot --title "Stand-by ..." -- sleep 1.5
workgroup="WORKGROUP"
BRIGHT_BLUE='\033[1;34m'
BRIGHT_GREEN='\033[1;32m'
BRIGHT_YELLOW='\033[1;33m'
NC='\033[0m' # No Color
echo -e "${BRIGHT_BLUE}Querying NetBIOS names for:${NC} ${BRIGHT_GREEN}$workgroup${NC}"
# Perform NetBIOS name lookup for the specified workgroup and variations of case's
for name in "$workgroup" "samba" "Samba" "SAMBA" "WORKGROUP" "workgroup"; do
echo -e "${BRIGHT_YELLOW}NetBIOS Name:${NC} ${BRIGHT_GREEN}$name${NC}"
nmblookup -S "$name"
echo "----------------------------------------"
done
echo -e "${BRIGHT_BLUE}Script completed.${NC}"
echo ""
sleep 2
display_message "[${GREEN}✔${NC}] Seek which pc's are acting as SERVERS"
nmblookup -S '*'
