Usually, a Linux system has an /etc/passwd and a /etc/group where all users are defined.
Here, in my case Aurora, both files contain only a couple of entries. Also /usr/etc/passwd and /usr/etc/group contain only a couple of entries.
For example id avahi gives
uid=70(avahi) gid=70(avahi) groups=70(avahi)
But where is this user (and all the other users) defined?
Honestly, I don’t know why your /etc/passwd and /etc/group only have a couple of entries (your user ID and group are there, right)? Mine work fine and contain entries. /etc is writable in Aurora.
wc -l /etc/passwd gives 7
wc -l /usr/etc/passwd gives 5
I didn’t say that things aren’t working fine but like to understand where all the other users are defined.
I found it. All the missing users are defined in /usr/lib/passwdand the missing groups in /usr/lib/group
I had no idea they were doing that (moved them). thanks!
inffy
February 13, 2026, 6:58pm
6
groups are in /usr/lib/groups.
This is how the dx-group recipe handles that
if gum confirm "Do you want to also install the default development flatpaks?" ; then
ADD_DEVMODE=1 ujust install-system-flatpaks 0 1
fi
if gum confirm "Do you want to install extra monospace fonts?" ; then
brew bundle install --file=/usr/share/ublue-os/homebrew/fonts.Brewfile
fi
echo "Use ujust dx-group to add your user to the correct groups and complete the installation after rebooting into the development image"
# Configure docker,incus-admin,libvirt, container manager, serial permissions
[group('System')]
dx-group:
#!/usr/bin/pkexec bash
append_group() {
local group_name="$1"
if ! grep -q "^$group_name:" /etc/group; then
echo "Appending $group_name to /etc/group"
grep "^$group_name:" /usr/lib/group | sudo tee -a /etc/group > /dev/null
fi
GROUPS_ADD=("docker" "incus-admin" "libvirt" "dialout")
Me neither. But when one has only 7 entries in /etc/passwd one thinks twice. I am happy I found it.
Now I try to understand how, for instance, passwd gets information from both /etc/passwd and /usr/lib/passwd
nss comes into my mind and looking into /etc/authselect/nsswitch.conf I see
passwd: files altfiles systemd
shadow: files systemd
group: files [SUCCESS=merge] altfiles [SUCCESS=merge] systemd
This helps a bit. altfiles seems to be important. The next question is where altfiles is defined.
Not yet looked into details but it seems that things are managed by package authselect-libs
I don’t know enough about the inner workings of bazzite or the logic behind the unorthodox location of /usr/lib/group, but I do see multiple errors in the journal about failure to resolve certain groups-- groups I can see in /usr/lib/group, but have, of course, been removed from /etc/group.
