Waydroid failing to start fixed
paste this in your terminal for waydroid to work.
sudo setenforce 0
Warning: this disables selinux wich is VERY important
to your systems security.
This command is not perment so its supposed to be re applied after every reboot. enabling it with the permenent option
is NOT recommended.
But for some reson its still in effect when I reboot?
I know very little of selinux so use at your on risk.
what exactly was your error? disabling selinux permanently is done trough setting SELINUX=disabled in /etc/selinux/config. but indeed it is not recommended.
