V42loopback Missing
I installed Bluefin to take advantage of v42loopback being included by default.
However, the virtual camera in the OBS flatpak no longer shows the virtual camera. The virtual camera depends on the v42loopback kernel module.
I first installed ver 38 of Bluefin-dx and then rebased to the latest version.
The virtual camera in OBS was working at this time.
I then rebased back to the gts version to try and fix a different issue. That issue was not fixed with the downgrade so I rebased back to version 39 (latest).
Now the virtual camera in the OBS flatpak is no longer available as an option. I think Something happened with the kmod which contains v42loopback and I’d like to get that fixed and working again but I don’t know how to do that.
temporarily removed due to it not working on the new kernel, it is being fixed upstream as far as i know.
If you rebase to a 40 version (which is pre-release) the module is included.
Unfortunately, Fedora bumped the kernel for 38 and 39 to the same version as 40. RPMFusion did not have a compatible rpm for 38/39. RPMFusion is aware of the situation and it should be back in 38/39 soon*
That makes sense and I appreciate the information. Cheers!
