Can I use systemctl enable some_service and systemctl start --user some_service?
If not, what is the alternative.
Yeah they work normally, as long as there is a service to start
I’m a beginner…
I wanted to have OneDrive starting at boot. I now remember I installed it with homebrew.
Can I use systemctl for that?
You might want to refer to this post:
So I should ask “How to add onedrive (or: a homebrew-application) to systemctl on Fedora Silverblue”?
I tried that in a websearch but no easy answers so far. Will try again later, but feedback is welcome ![]()
Thanks! I tried that in the past, without success (the homebrew installation is fine, but the GUI not). I found new info in that tread, but got stuck again. I asked there.
If I succeed, I post my solution.
How do I do @reboot with systemctl and also running a backup program at month end at a certain time.
currently, I do a @reboot within crontab and for that @reboot, I have en entry similar to:
[[date -d tomorrow +%d == “01” ]] && message Satensteinl “Tomorrow is the first, backups today”
and also, I can schedule the backup using crontab to run the backups after 10pm today
You say systemd can do that check at every reboot?
