While browsing the Docs i noticed that it said:
Distrobox containers can be created and managed graphically with DistroShelf which is pre-installed.
yet I didn’t have that installed, since that is apparently a new addition to Bazzite. So while searching for an answer I came across the following in a Bluefin anouncement
Run
ujust install-system-flatpaksto update your applications if you want them reinstalled as flatpaks, or just choose them individually if you prefer.
That command doesn’t seem to exist on Bazzite instead there is _ujust install-system-flatpaks which took some searching to find
So my question is, why is that command not run alongside ujust update? If default system flatpaks change I would expect to get the new ones as well.
