Update problem
Hi,
I have a problem with updating
System Updater module status
System module
Executing update
Pulling manifest: ostree-image-signed:docker://ghcr.io/ublue-os/bazzite-nvidia-open:stable
Checking out tree d873f6f...done
Inactive requests:
  gcc (already provided by gcc-16.2.1-3.fc45.x86_64)
  policycoreutils-python-utils (already provided by policycoreutils-python-utils-3.11-2.fc45.noarch)
  kernel-devel (already provided by kernel-devel-7.2.15-ogc1.1.fc45.x86_64)
  make (already provided by make-1:4.4.1-13.fc45.x86_64)
  splix (already provided by splix-2.0.1-7.fc45.x86_64)
  python3-pyside6 (already provided by python3-pyside6-6.11.2-3.fc45.x86_64)
Enabled rpm-md repositories: updates fedora MEGAsync copr:copr.fedorainfracloud.org:atim:heroic-games-launcher brave-browser copr:copr.fedorainfracloud.org:deltacopy:darkly copr:copr.fedorainfracloud.org:hazel-bunny:ricing copr:copr.fedorainfracloud.org:infinality:kwin-effects-better-blur-dx updates-archive
Importing rpm-md...done
rpm-md repo 'updates' (cached); generated: 2026-11-03T01:04:10Z solvables: 7653
rpm-md repo 'fedora' (cached); generated: 2026-10-30T08:28:54Z solvables: 75855
rpm-md repo 'MEGAsync' (cached); generated: 2026-10-24T12:27:01Z solvables: 34
rpm-md repo 'copr:copr.fedorainfracloud.org:atim:heroic-games-launcher' (cached); generated: 2026-09-12T11:58:22Z solvables: 2
rpm-md repo 'brave-browser' (cached); generated: 2026-10-30T16:50:58Z solvables: 471
rpm-md repo 'copr:copr.fedorainfracloud.org:deltacopy:darkly' (cached); generated: 2026-10-25T03:57:37Z solvables: 32
rpm-md repo 'copr:copr.fedorainfracloud.org:hazel-bunny:ricing' (cached); generated: 2026-10-28T06:28:35Z solvables: 363
rpm-md repo 'copr:copr.fedorainfracloud.org:infinality:kwin-effects-better-blur-dx' (cached); generated: 2026-11-03T15:38:41Z solvables: 10
rpm-md repo 'updates-archive' (cached); generated: 2026-08-21T13:38:41Z solvables: 0
Resolving dependencies...done
 Problem: conflicting requests
  - package logitech-trueforce-0.42.6-1.fc45.noarch from @System requires (dkms-logitech-trueforce = 0.42.6 if dkms), but none of the providers can be installed
Error occurred while waiting for external command
Brew module
==> Updating Homebrew...
Already up-to-date.
Flatpak module
Informacja: page.kramo.Cartridges jest niewspierane z powodu: This application is no longer maintained.
Nothing to update.
Wyszukiwanie aktualizacji…
Informacja: program page.kramo.Cartridges, gałąź stable jest niewspierany z powodu:
Nothing to update.
Exited with failed updates.
System Update
Job for uupd-manual.service failed because the control process exited with error code.
See "systemctl status uupd-manual.service" and "journalctl -xeu uupd-manual.service" for details.
Updates finished with errors!
1 update module(s) failed: System Update
uupd-manual.service: Main process exited, code=exited, status=1/FAILURE
uupd-manual.service: Failed with result 'exit-code'.
Failed to start uupd-manual.service - Universal Blue Update Oneshot Service - Manual Activation.
uupd-manual.service: Consumed 1.271s CPU time over 37.600s wall clock time, 43M memory peak.
Command finished with exit code 1 and exit status 0
The update has failed. Read the above output for more details.
and
grzegorz@bazzite:/var/home/grzegorz$ rpm-ostree update
Checking out tree d873f6f... done
Inactive requests:
Importing rpm-md... done
you seem to have layered some packages and this is the reason why layering is not recommended.
You need to remove the packages with rpm-ostree reset and then run the update
Ok. Thank you. I’ll try.
