I know that this is a wide-spread problem but I was wondering if anyone has fixed this in Bazzite.
My 7900XT in Windows reports around 390ish watts. I know the Windows AMD driver is reporting total board power while LACT lets you set the power limit for the GPU core. It allows me to “set” a limit of 333W which makes sense if the total board power would be around 390ish.
Unfortunately even after setting the limit to 333W I never see more than 291W. I can also tell by the temps that it is not just a reporting error. The temps are a bit higher in Windows with the power limit maxed.
If anyone know how to fix this I would greatly appreciate it.
