Tailscale VPN on Bluefin
Bluefin comes with Tailscale integrated out of the box. The tailscale command is available via the command line. The Tailscale documentation will show you how to set it up. Wireguard tools are also available if you want to use another provider.
There are two extensions for tailscale that are used in Bluefin. We started with tailscale-status but are moving to tailscale-gnome-qs in Fedora 39 and newer:
Here’s what it looks like:
Both extensions require a sudo tailscale set --operator=$USER so that your user account can toggle things like the VPN, etc.
See Managing Extensions for instructions on how to turn off the extension if you don’t use Tailscale.
Any option for having a similar integration on Aurora?
If someone finds a thing for KDE please let us know asap, it’d be awesome to have that.
Hi, you can try KtailCtl. It’s just an app that sits on the system tray and works similarly to gnome extension
Is tailscale-gnome-qs working in F40?
Mine shows “incompatible with current version of gnome”.
gnome-shell-extension-tailscale-gnome-qs-0.0.git.38.0dd06f63-1.fc40.src.rpm
In progress here: Tailscale QS not working on Bluefin 40 · Issue #1319 · ublue-os/bluefin · GitHub
