Swtpm Permission Denied
I’m having an issue starting my guest system in Virtual Machine Manager.
I first installed ver 38 of Bluefin-dx and then rebased to the latest version.
I created the Virtual Machine on the latest version (39) and it was working fine.
I then rebased back to the gts version and that’s when this issue started with the swtpm error message. I rebased back to version 39 hoping it was the version downgrade that caused the problem but the swtpm error persists.
Can someone help me get this fixed? I need the Virtual Machine functioning for work.
Here’s the error message from VMM when running ‘sudo virsh start image_name’.
Error starting domain: operation failed: swtpm died and reported: libvirt: error : cannot execute binary /usr/bin/swtpm: Permission denied
File “/usr/share/virt-manager/virtManager/asyncjob.py”, line 72, in cb_wrapper
callback(asyncjob, *args, **kwargs)
File “/usr/share/virt-manager/virtManager/asyncjob.py”, line 108, in tmpcb
callback(*args, **kwargs)
File “/usr/share/virt-manager/virtManager/object/libvirtobject.py”, line 57, in newfn
ret = fn(self, *args, **kwargs)
File “/usr/share/virt-manager/virtManager/object/domain.py”, line 1402, in startup
self._backend.create()
File “/usr/lib64/python3.12/site-packages/libvirt.py”, line 1373, in create
raise libvirtError(‘virDomainCreate() failed’)
libvirt.libvirtError: operation failed: swtpm died and reported: libvirt: error : cannot execute binary /usr/bin/swtpm: Permission denied
check what is the SELinux fcontexts for /usr/bin/swtpm. We have a service for applying the right contexts on boot called swtpm-workaround.service in -dx.
Here’s what I’m getting by running: matchpathcon -V /usr/bin/swtpm
/usr/bin/swtpm has context system_u:object_r:bin_t:s0, should be system_u:object_r:swtpm_exec_t:s0
That is correct. However, try checking with ls -lZ /usr/bin/swtpm as well.
Please check the logs for swtpm in /var/log/swtpm as well.
Here is the output of ls -lZ /usr/bin/swtpm:
-rwxr-xr-x. 5 root root system_u:object_r:bin_t:s0 42136 Dec 31 1969 /usr/bin/swtpm
I compared both the matchpathcon and ls commands against a fresh install in a VM and the permissions are the same between my system and the VM.
I don’t see any errors in the swtpm log.
Starting vTPM manufacturing as tss:tss @ Mon 08 Apr 2024 10:57:17 AM PDT
Successfully created RSA 2048 EK with handle 0x81010001.
  Invoking /usr/bin/swtpm_localca --type ek --ek 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 --dir /tmp/swtpm_setup.certs.5MFDM2 --logfile /var/log/swtpm/libvirt/qemu/RDPWindows-swtpm.log --vmid RDPWindows:c746833a-557d-472f-a7f0-d9baab72e7c0 --tpm-spec-family 2.0 --tpm-spec-level 0 --tpm-spec-revision 164 --tpm-manufacturer id:00001014 --tpm-model swtpm --tpm-version id:20191023 --tpm2 --configfile /etc/swtpm-localca.conf --optsfile /etc/swtpm-localca.options
Successfully created EK certificate locally.
  Invoking /usr/bin/swtpm_localca --type platform --ek 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 --dir /tmp/swtpm_setup.certs.5MFDM2 --logfile /var/log/swtpm/libvirt/qemu/RDPWindows-swtpm.log --vmid RDPWindows:c746833a-557d-472f-a7f0-d9baab72e7c0 --tpm-spec-family 2.0 --tpm-spec-level 0 --tpm-spec-revision 164 --tpm-manufacturer id:00001014 --tpm-model swtpm --tpm-version id:20191023 --tpm2 --configfile /etc/swtpm-localca.conf --optsfile /etc/swtpm-localca.options
Successfully created platform certificate locally.
Successfully created NVRAM area 0x1c00002 for RSA 2048 EK certificate.
Successfully created NVRAM area 0x1c08000 for platform certificate.
Successfully created ECC EK with handle 0x81010016.
  Invoking /usr/bin/swtpm_localca --type ek --ek x=8c183acb803a1ef172f9c0b2b870fdfe59bb24aafaf144f8dd17df95b8dea7f1099c2eda43dd8f6fa825cf635d20048b,y=0363309c332e1ca08d5f8d45663cae7dceb37463c8058d1f87e77ff13f2e985078d63a682c0c2072931e67e83c17c188,id=secp384r1 --dir /tmp/swtpm_setup.certs.5MFDM2 --logfile /var/log/swtpm/libvirt/qemu/RDPWindows-swtpm.log --vmid RDPWindows:c746833a-557d-472f-a7f0-d9baab72e7c0 --tpm-spec-family 2.0 --tpm-spec-level 0 --tpm-spec-revision 164 --tpm-manufacturer id:00001014 --tpm-model swtpm --tpm-version id:20191023 --tpm2 --configfile /etc/swtpm-localca.conf --optsfile /etc/swtpm-localca.options
Successfully created NVRAM area 0x1c00016 for ECC EK certificate.
Successfully activated PCR banks sha256 among sha1,sha256,sha384,sha512.
Successfully authored TPM state.
Ending vTPM manufacturing @ Mon 08 Apr 2024 10:57:17 AM PDT
ls -lZ is showing that swtpm does not have the right label.
Do you have our swtpm-workaround.service disabled?
That relabels swtpm on boot.
That was the issue. The swtpm-workaround.service was not enabled. I fixed that and I no longer have the permission error. Thank you for helping me sort this out.
I can confirm it also happened on my Bluefin that rebased to :latest (with Fedora 40).
Well, my initial problem was that libvirt didn’t have permissions to create a log on /var/log/libvirt, and after fixing that, the swtpm error appeared.
I had to use these commands to fix the permissions for SELinux when trying to use VMM (or any virtual machine at all).
sudo restorecon -rv /var/log/libvirt/
systemctl restart swtpm-workaround.service
The swtpm-workaround.service was enabled and running, but for some reason the problem persisted until I restarted it with restart.
Looks like a few people have run into this error. We can probably setup something to auto run this on boot. Swtpm and VMs are pretty critical for the -dx experience.
If someone stumbles upon not being able to enable the network in VMM because it can’t create a folder below libvirt, you can apply the same SELinux command to it.
sudo restorecon -rv /var/lib/libvirt
