Slow bootup time - Bazzite
Hi,
I’m relatively new to Bazzite, and I’ve recently run into an issue with my boot up time slowing down from about 20 seconds to 1 minute 30 seconds. I’ve done some research already and I’ve found that one of the potential ways to fix the issue is by drain residual charge in my PC. It ended up working, but then the issue started persisting again. I have run the systemd-analyze blame command and this is what I got:
1min 18.410s sys-devices-platform-MSFT0101:00-tpm-tpm0.device
1min 18.410s dev-tpm0.device
1min 18.148s sys-module-fuse.device
1min 18.029s dev-disk-by\x2dpath-pci\x2d0000:04:00.0\x2dnvme\x2d1.device
1min 18.029s dev-disk-by\x2did-nvme\x2dSamsung_SSD_9100_PRO_2TB_S7YCNJ0L219079L_1.device
1min 18.029s dev-disk-by\x2did-nvme\x2deui.002538a26140fcb7.device
1min 18.029s dev-disk-by\x2did-nvme\x2dSamsung_SSD_9100_PRO_2TB_S7YCNJ0L219079L.device
1min 18.029s dev-nvme0n1.device
1min 18.029s sys-devices-pci0000:00-0000:00:01.2-0000:04:00.0-nvme-nvme0-nvme0n1.device
1min 18.029s dev-disk-by\x2ddiskseq-1.device
1min 18.029s sys-devices-platform-serial8250-serial8250:0-serial8250:0.2-tty-ttyS2.device
1min 18.029s dev-ttyS2.device
1min 18.028s dev-disk-by\x2ddesignator-esp.device
1min 18.028s dev-disk-by\x2did-nvme\x2dSamsung_SSD_9100_PRO_2TB_S7YCNJ0L219079L\x2dpart1.device
1min 18.028s dev-nvme0n1p1.device
1min 18.028s dev-disk-by\x2dpartlabel-EFI\x5cx20System\x5cx20Partition.device
1min 18.028s dev-disk-by\x2dpartuuid-fc7547ec\x2d8339\x2d4337\x2da3af\x2dba57c05c0ea5.device
1min 18.028s dev-disk-by\x2duuid-D832\x2dB803.device
1min 18.028s dev-disk-by\x2did-nvme\x2deui.002538a26140fcb7\x2dpart1.device
1min 18.028s dev-disk-by\x2dpath-pci\x2d0000:04:00.0\x2dnvme\x2d1\x2dpart1.device
1min 18.028s dev-disk-by\x2dpath-pci\x2d0000:04:00.0\x2dnvme\x2d1\x2dpart-by\x2dpartuuid-fc7547ec\x2d8339\x2d4337\x2da3af\x2dba57c05c0ea5.device
1min 18.028s dev-disk-by\x2dpath-pci\x2d0000:04:00.0\x2dnvme\x2d1\x2dpart-by\x2dpartlabel-EFI\x5cx20System\x5cx20Partition.device
1min 18.028s sys-devices-pci0000:00-0000:00:01.2-0000:04:00.0-nvme-nvme0-nvme0n1-nvme0n1p1.device
1min 18.028s dev-disk-by\x2dpath-pci\x2d0000:04:00.0\x2dnvme\x2d1\x2dpart-by\x2duuid-D832\x2dB803.device
1min 18.028s dev-disk-by\x2did-nvme\x2dSamsung_SSD_9100_PRO_2TB_S7YCNJ0L219079L_1\x2dpart1.device
1min 18.028s dev-disk-by\x2ddiskseq-1\x2dpart1.device
1min 18.028s dev-disk-by\x2dpath-pci\x2d0000:04:00.0\x2dnvme\x2d1\x2dpart-by\x2dpartnum-1.device
1min 18.023s dev-ttyS3.device
1min 18.023s sys-devices-platform-serial8250-serial8250:0-serial8250:0.3-tty-ttyS3.device
1min 18.023s dev-disk-by\x2ddiskseq-1\x2dpart3.device
1min 18.023s dev-disk-by\x2dpartuuid-184c8cfd\x2dbd3f\x2d497c\x2da4e8\x2d3f3a4a9f9e7c.device
1min 18.023s sys-devices-pci0000:00-0000:00:01.2-0000:04:00.0-nvme-nvme0-nvme0n1-nvme0n1p3.device
1min 18.023s dev-disk-by\x2did-nvme\x2dSamsung_SSD_9100_PRO_2TB_S7YCNJ0L219079L_1\x2dpart3.device
1min 18.023s dev-disk-by\x2duuid-50057f4f\x2d32f0\x2d47f4\x2d8262\x2d6dd13a797045.device
1min 18.023s dev-disk-by\x2dpath-pci\x2d0000:04:00.0\x2dnvme\x2d1\x2dpart-by\x2dpartnum-3.device
1min 18.023s dev-disk-by\x2did-nvme\x2deui.002538a26140fcb7\x2dpart3.device
1min 18.023s dev-disk-by\x2dlabel-bazzite.device
1min 18.023s dev-disk-by\x2dpath-pci\x2d0000:04:00.0\x2dnvme\x2d1\x2dpart-by\x2duuid-50057f4f\x2d32f0\x2d47f4\x2d8262\x2d6dd13a797045.device
1min 18.023s dev-disk-by\x2dpath-pci\x2d0000:04:00.0\x2dnvme\x2d1\x2dpart3.device
1min 18.023s dev-disk-by\x2did-nvme\x2dSamsung_SSD_9100_PRO_2TB_S7YCNJ0L219079L\x2dpart3.device
1min 18.023s dev-disk-by\x2dpath-pci\x2d0000:04:00.0\x2dnvme\x2d1\x2dpart-by\x2dlabel-bazzite.device
1min 18.023s dev-disk-by\x2dpath-pci\x2d0000:04:00.0\x2dnvme\x2d1\x2dpart-by\x2dpartuuid-184c8cfd\x2dbd3f\x2d497c\x2da4e8\x2d3f3a4a9f9e7c.device
1min 18.023s dev-nvme0n1p3.device
1min 18.023s sys-devices-platform-serial8250-serial8250:0-serial8250:0.1-tty-ttyS1.device
1min 18.023s dev-ttyS1.device
1min 18.023s dev-disk-by\x2ddiskseq-1\x2dpart2.device
1min 18.023s dev-disk-by\x2did-nvme\x2dSamsung_SSD_9100_PRO_2TB_S7YCNJ0L219079L\x2dpart2.device
1min 18.023s sys-devices-pci0000:00-0000:00:01.2-0000:04:00.0-nvme-nvme0-nvme0n1-nvme0n1p2.device
1min 18.023s dev-disk-by\x2dpath-pci\x2d0000:04:00.0\x2dnvme\x2d1\x2dpart-by\x2dpartuuid-20ae1e35\x2d41d0\x2d4abb\x2db39c\x2d74a13814a6b1.device
1min 18.023s dev-disk-by\x2dpath-pci\x2d0000:04:00.0\x2dnvme\x2d1\x2dpart2.device
1min 18.023s dev-disk-by\x2dlabel-bazzite_xboot.device
1min 18.023s dev-disk-by\x2did-nvme\x2dSamsung_SSD_9100_PRO_2TB_S7YCNJ0L219079L_1\x2dpart2.device
1min 18.023s dev-disk-by\x2did-nvme\x2deui.002538a26140fcb7\x2dpart2.device
1min 18.023s dev-disk-by\x2dpartuuid-20ae1e35\x2d41d0\x2d4abb\x2db39c\x2d74a13814a6b1.device
1min 18.023s dev-disk-by\x2dpath-pci\x2d0000:04:00.0\x2dnvme\x2d1\x2dpart-by\x2duuid-df2a1390\x2d4f70\x2d4295\x2db9c0\x2d2e52f446c32a.device
1min 18.023s dev-disk-by\x2dpath-pci\x2d0000:04:00.0\x2dnvme\x2d1\x2dpart-by\x2dpartnum-2.device
1min 18.023s dev-nvme0n1p2.device
1min 18.022s dev-disk-by\x2duuid-df2a1390\x2d4f70\x2d4295\x2db9c0\x2d2e52f446c32a.device
1min 18.022s dev-disk-by\x2dpath-pci\x2d0000:04:00.0\x2dnvme\x2d1\x2dpart-by\x2dlabel-bazzite_xboot.device
1min 18.021s dev-ttyS0.device
1min 18.021s sys-devices-platform-serial8250-serial8250:0-serial8250:0.0-tty-ttyS0.device
1min 18.015s sys-devices-platform-MSFT0101:00-tpmrm-tpmrm0.device
1min 18.015s dev-tpmrm0.device
1min 18.007s sys-module-configfs.device
1min 16.880s dracut-initqueue.service
16.320s NetworkManager-wait-online.service
2.844s plasmalogin.service
(There’s more, but they are all less than 2 seconds)
Does anyone know what the issue could be? I’m quite confused as to what could be the issue.
Here are my PC specs if that’ll help:
AMD Ryzen 9800x3D
32 GB RAM 6000MHz DDR5
2 TB Samsung 9100 Pro
MSI MAG x870 Tomahawk Wifi 7 motherboard
AMD Radeon 9070 XT XFX Mercury OC Model
