Scaling issues on bluefin
Hi all!
First of all, thank you Jorge and the rest of the team for creating Bluefin! You are amazing and I cannot thank you enough for this fine piece of engineering art! Over the couple of weeks, I have been telling devops people and IT scientists I know about it :slight_smile:
I have a small problem, though: compared with my previous Fedora 40 installation (also Gnome), everything on Bluefin seems a bit to large with scaling factor set to 100%. I am talking about font sizes, topbar width and topbar font size, font sizes in all the apps (flatpak and those which are part of the image), also Gnome menus are a bit too big. Is there any way I could set them to the same size vanilla Fedora does?
Thanks for the help!
The Refine app (itโ€™s in flathub) will let you set the font size to whatever preference you want.
Thank you, that did the trick!
But should there be a difference? Or are you using the Same defaults Like stock-fedora?
