Running uCore in a live usb
Hi:
I’m not sure if the question makes sense for you but, as I would like to substitute UNRAID for uCore and I like the UNRAID way of running from a live usb I wonder if uCore can be installed and used same way.
Is it possible? Thanks in advance.
Yes, but you will need to ensure that your ignition file sets up your install for being more suited to running from a flash drive. If you use a disk more suited for internal use, but connected via USB it will not have the same write considerations.
Thanks!
The installing procedure is using Fedora Media Writer also?
I strongly recommend looking at the install procedure for coreOS since it’s quite a bit different.
FCOS have good documentation on this, it might need some tweaks for a bootc base but hopefully provides a good insight. Keep us updated, it would be good to see how you achieve this.
